door lock knob on 59 corvette - NCRS Discussion Boards
  • David B.
    • July 31, 2004
    • 15
    How do I remove the door lock knob on a 59
    Re: door lock knob on 59 corvette
    Gently push the door panel back/away from the knob. Look around at the back side of the knob and you should see a clip holding the knob to a groove cut into the shaft the knob rides on.
    Use a pair of needle nose pliers or an L-shaped hook to grab the clip and pull it off the knob sideways. The knob should now simply lift off the shaft.
    • Don H.
      • December 1, 1981
      • 1496
      Another trick is to use a "shop towell" and spin it around while working it in behind the knob. Many times the fabric will catch the end of the clip and pull it off. Don H.
      • David B.
        • July 31, 2004
        • 15
        Thanks for your help Don!
        Dave Bauer
