1968 cast iron thermostat housing - NCRS Discussion Boards
  • Robert M.
    • January 1, 1992
    • 78
    In the the 1968 judging manaul it states that a cast iron thermostat housing was used, I have an early 68 435 horse (serial# 3907) car. Is this correct? and if so what is the part # or how can I identify it.
    Thanks Bob Moon
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1968 cast iron thermostat housing
    My early nearly all original 68 427/400 is aluminum.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Jack C.
      • 1090
      It's difficult to see the pn# because of the carb but it looks like 3677660 and the pn#is on the base of the housing and not the neck where the hose attaches.
      Jack Corso
        • 43247
        Thanks Bob Moon
        Bob------
        All 1968's, except L-88, used the GM #3877660 ALUMINUM thermostat housing.
        • Dick W.
          • 10483
          You can see that the manual is about as clear as mud on that issue! Comments duly noted
          Dick Whittington
          • Robert M.
            • January 1, 1992
            • 78
            Thanks Guys; The reason I asked my 427-435 also has the 3776660 aluminum housing but the part # is located on the neck not on the housing as Jack Corso described.
