1962 curb height - NCRS Discussion Boards
1962 curb height
  • Michael D.
    Infrequent User
    • November 1, 1986
    • 25
    1962 curb height
    I am replacing my rear springs with original re arc springs, what should the curb height be on the car and where do I measure it from.
    Mike
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1962 curb height
    Buy an AIM.
    • Terry D.
      • May 31, 1987
      • 2697
      Those dimensions are also in the ST-12 Manual. Good idea to purchase both. The NCRS store has both by the way. If I was home I would look it up for you but won't be there till Tuesday. Someone will surely pipe in with that for you.
      • John F.
        • March 23, 2008
        • 2419
        Where is it in the assembly manual? Can't find the page either.
        • John T.
          NCRS Financial Officer
          • January 1, 1983
          • 293
          The dimensions per the ST-12.
          Measured from the bottom of the rocker molding to the ground. 6.7" at the front end and 8.2" at the rear. This is in section 0.
          Section 14 calls out a "Vehicle Height" of 11" +/- 1/2" for standard springs and 8 3/4" for H.D. I did not find where it shows how this is measured.
          Good luck
          John
          • John F.
            • March 23, 2008
            • 2419
            Thanks for the help but I may not have the right manuals that everyone has been referring to. I have the 1962 Corvette Assembly Manual, 53-62 Corvette Servicing Guide, and the 61-62 CTIMJG. I can't find the pages you are referring to.
              The front ride height measurement is shown in the ST-12 on page 3-2, in the photo (figure 3); the desired dimension is shown in the "Specifications" section in the back (Section 14) under "Front Suspension", "Vehicle Height".
              I don't have a '62 Assembly Manual, but the rear ride height is shown in the '57 A.I.M. at the end of Section 3, in a chart that shows the dimension between the top of the axle tube and the bottom of the frame directly above it as 3.80" at curb height; the '62 A.I.M. should have a similar chart.
              Both of the above measurements are independent of tire size - they measure actual deflection of the spring; the rocker-to-ground measurements will vary due to tire size.
              • John F.
                • March 23, 2008
                • 2419
                Will new shocks in the rear increase the curb height a little? Any recs?
