shocks - NCRS Discussion Boards
shocks
  • Sal R.
    • December 10, 2007
    • 160
    shocks
    can any one tell me or show a picture of the correct shocks for a 65 roadster L I corvette show a heavy duty rear shock I am not sure what to purchase your help is needed.
    Thanks Sal R
  • Donald T.
    • September 30, 2002
    • 1319
    Re: shocks
    Sal,
    Here are pics of an original set of front shocks for a 65. They are date coded 97-65.
    • Sal R.
      • December 10, 2007
      • 160
      Re: shocks
      Thank you so much all the front shocks I have seen for sale are Delco brand painted black
      • Donald T.
        • 1319
        Re: shocks
        Here are pics of an original set of rear shocks dated 32-65.
          Re: shocks
          Sal -
          Delco hasn't made the original-configuration gray shocks for decades, and hasn't manufactured their own shocks for many years; what you'll get today from Delco is a shock made by an aftermarket supplier (like Gabriel or Monroe), painted black, with a Delco sticker on it. Remove the sticker, paint them gray, add the broadcast sticker, and that's about the best you can do; the deduction is minimal.
          • Sal R.
            • December 10, 2007
            • 160
            Re: shocks
            what is the broadcast sticker
            • Larry M.
              • January 1, 1992
              • 2689
              Re: shocks
              Thanks Sal R
              Sal:
              I agree with John Hinckley that your best option is probably to buy the current Delco replacement shocks for your car, remove the Delco labels, paint them the correct gray, and install reproduction broadcast code labels. This way you get a shock that looks reasonably correct and performs well without costing to much. This is what most folks do.
              HOWEVER, if you are going strictly for judging points and dollars are not a primary concern, you can purchase original (used) shocks, or purchase new shocks that have the correct embossed logos and dates codes.
              If you want to pursue either of these alternatives, let me know and I will provide details. However, this information is also in the DRIVELINE.
              Larry
                Re: shocks
                Sal -
                Those are the black-on-white "EK" and "EM" stickers that identified the shocks for the line workers; see "Shocks" in the "Front Suspension" and "Rear Suspension" section of the Chassis chapter in the JG.
                • Sal R.
                  • December 10, 2007
                  • 160
                  Re: shocks
                  Thanks You guys. Larry I would like date coded shocks please forward any info you can
                  Thanks again
                  Sal
                  • Sal R.
                    • December 10, 2007
                    • 160
                    Re: shocks
                    I would be interested in finding dated coded shocks
                    • Larry M.
                      • January 1, 1992
                      • 2689
                      Re: shocks
                      Sal:
                      Check your private messages. Upper right-hand box just below your "log-in name". Sent yesterday afternoon. If you did not receive, let me know.
                      Larry
                      • Sal R.
                        • December 10, 2007
                        • 160
                        Re: shocks
                        I did get in touch with Dave I will have to cash in some bonds to afford the shocks so I think for now I will go the other way. Just not sure exactly what color paint to get
                        Thank you so much for your help Larry.
                        Sal R
                        • Larry M.
                          • January 1, 1992
                          • 2689
                          Re: shocks
                          Sal:
                          The correct gray paint can be purchased from a number of sources: Long Island Corvette Supply #45-04, Paragon #2682, or Quanta #07-03. About 7-10 dollars a can.
                          Some people think the Quanta paint has the best color match, but who knows for sure? The Quanta website is http://www.gastanks.com
                          Any of the three vendors listed above should have an acceptable product.
                          Larry
                          • Thomas N.
                            • June 30, 1998
                            • 45
                            Re: shocks
                            I used Dupli Color : DE1611 Ford Gray, from the local AutoZone. If you search the archives many have used this with success.
