67 L71 tachometer tester - NCRS Discussion Boards
+ More Options
Posts
  • Tom R.
    • April 7, 2008
    • 135
    Anyone know how to hookup a RPM tester to a BB w/TI? It reads 0 when connected normally as to a points distributor. Simply wanting a check for the gauge in the dash. The car is running fine so I'm assuming the TI amplifier requires a different connection.
    Re: 67 L71 tachometer tester
    Tom -
    The '67 Chassis Service Manual says test tach connections are the same as with the points system, but adds: "...however, before attempting to connect a test tachometer into the primary circuit, check with your instrument supplier to ensure that satisfactory readings can be obtained and the breakerless system will not be damaged by the tachometer that is to be used."
    • Ken A.
      • July 31, 1986
      • 929
      As the book says, not a good idea.
