A-pillar stainless to windshield frame WS - NCRS Discussion Boards
  • Charles P.
    • April 30, 2005
    • 332
    What goes underneath the A pillar stainless/window foam weatherstripping. I removed 3 screws to get the WS and stainless off. What is underneath is real cruddy like clay. Is it adhesive or is there a part that seals it to the windshield frame? I suppose if you never drove it in the rain you could skip this. Thanks.
    • 3416
    Re: A-pillar stainless to windshield frame WS
    Hi Charles,
    On my 71 I found only very thick, sticky, black sealer, that is very similar to the 3M strip-calk, #08578, that is sold many places now, under the A- pillar SS trim. I did find a thin, sticky, black foam strip seal beween the 2 SS parts that make up the A-pillar trim.
    In regards to the clay like material, I found a chalky gray material that looked like it had come out of caulking-gun under the upper windshield header SS trim, but not under the A-pillar trim .
    • Charles P.
      • April 30, 2005
      • 332
      Yes, thats the same stuff. Nearly 40 years old and still sticky. It was flat and regular shaped, but came off in chunks, and could have been a gasket at one time. Hard to say. I will put a bead of 3M black weather strip adh. in there unless anyone has any better ideas. Thanks.
