C2 Tire size - NCRS Discussion Boards
C2 Tire size
  • Brian K.
    • September 19, 2007
    • 174
    C2 Tire size
    I would like to go with the Michelin Symmetry because of the white wall. They don't make a p205/75 which is what have now. They make a 205/70 & wondered what you guys have to say about it. I don't have clearance issues now but it is close so I don't want to go 215/75 which they do make. Also had a rcommendation on Uniroyal tigerpaw & Toyo Spectrum so please comment on those brands.
    Thanks!
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
    • 15697
    Re: C2 Tire size
    215/75R-15 is not a size I would recommend, but 215/70R-15 is; 205/70R-15 is not a good revs/mile match.
    Tires, like motor oil, are basically generic - built to a comprehesive set of industry/DOT standards. Brand/model mean little. Speed rating and UTQG is what you should use to evaluate tires.
    ...lot's of achive info on the subject.
    • Brian K.
      • 174
      Re: C2 Tire size
      Sorry Duke, I meant 215/70 is what I meant. I drive this car conservatively with an occasional stomping. I know you like the Pirelli's. Do you think the 215/70 is ok?
      66 Coupe
      66 Convertible
      2022 2LT Coupe
      67 Chevelle SS396
        • 15697
        Re: C2 Tire size
        A 215/70 is okay for all OE C2 wheels, but 6" are best.
        Regardless of how you drive the construction of "H" and higher speed rated tires is a considerable safety benefit. I would not consider anything less than an H-rated tire on any car I own.
        • Brian K.
          • 174
          Re: C2 Tire size
          Thanks again Duke,
          These are S rated and I can get the Uniroyal in a 205/75 white wall.
          I have knock-offs by the way.
          Regards.
          66 Coupe
          66 Convertible
          2022 2LT Coupe
          67 Chevelle SS396
          • William G.
            • January 1, 1988
            • 220
            Re: C2 Tire size
            I just put a set of Uniroyal Tiger Paw 215/70-15 on my unhit,body-never-off 66 roadster and they fit very well except for a very very slight rubbing on the frame when I turn the steering hard to the stop. The tires look nice, are quiet and smooth. I recommend them.
            • David D.
              • January 1, 2005
              • 416
              Re: C2 Tire size
              Bill,
              Can you post a picture of what they look like?
              David
              • Wayne P.
                • January 23, 2008
                • 444
                Re: C2 Tire size
                I am happy with the BF Goodrich TA 215x70xsr15 knock offs
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Re: C2 Tire size
                  Hey Duke --- I've got an old Goodyear FR78-15 Steel Belted Radial 'Custom Tread' whitewall with 90% remaining rubber. What current tire might be closest to a revs/mile and width match ?
                  • Brian K.
                    • 174
                    Re: C2 Tire size
                    Originally posted by David Duell (43184)
                    Bill,
                    David
                    Dave,
                    I just saw them at my dealer. The sidewall isn't unattractive like some that I've seen and the ww is a between 5/8 & 3/4 wide which I think looks perfect. Getting them put on next week.
                    Brian
                    66 Coupe
                    66 Convertible
                    2022 2LT Coupe
                    67 Chevelle SS396
                      • 15697
                      Re: C2 Tire size
                      I don't have a revs/mile figure or dimensional data for FR78-15, but my guess is a 205/75R-15 is a good match. If it's mounted and inflated you can measure the circumference and section width, then compute the inflated OD and compare to tire specs that you can find at The Tire Rack and mfgs. Web sites. Remember that for any size, past or present the range of acceptable dimensions are in a narrow range promulgated by the Tire and Rim Assc.
                      As you may recall, in that obsolete alphanumeric size scheme the first letter represented the load capacity, R was "radial" and "78" was the approximate aspect ratio.
