1961 T-10 Transmission Side Cover - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    What markings, codes or information would one find on an aluminum December 1960 BW T-10 main-case side cover?
    Thanks Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Gary C.
    Administrator
    • October 1, 1982
    • 17678
    Re: 1961 T-10 Transmission Side Cover
    Ray, thought some of the '61-2 guys would respond. '61 side cover is a T-10-148B. T10-148B side cover is stamped with that number on the inside. The T10-148B side cover outside has large gusset between the two shift lever posts, a smaller gusset on the rear shift post that from the outside of the post and is tapered to towards the edge. A short stubby gusset from the top of the shift post and gussets from the bottom of the shift post to the edge. That's as best as I can remember. Wayne Loron wrote a Restorer article years ago on 4 speeds and it's probably on the 61-2 CD-ROM available from the NCRS store. Hope this helps. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
      Ray -
      Here's what the T10-148B side cover looks like that Gary described above.
      • Ray C.
        • June 30, 2001
        • 1132
        Gary & John
        Thanks for the responses!
        John, there seems to be a date code on the outside of the cover in the picture. I Have a T-10-148B cover that came off a 1968 T-10-D case (small front bearing) service replacement transmission and there are no markings on the outside.
        Thanks for the help!
        Ray
        Ray Carney
