What's Wrong with This Picture - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
  • Mike M.
    • May 31, 1974
    • 8400
    Re: What's Wrong with This Picture
    valve wasn't staked adequately and fell out of its home.mike
    • David D.
      • January 1, 2005
      • 416
      I agree.....
      IF my assumption is correct that this is a Fuel Pump.
      If not, all bets are off on my 2 cents.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Agree w/Mikie - easy fix...
        • Joe C.
          • August 31, 1999
          • 4598
          The dislodged valve is for the inlet chamber of the pump, which means that it has been contacting the stem/diaphragm/retainer saucers all along. I'll post more pictures of what I find when I open up the remainder of the pump, tomorrow.
          Believe it or not, the car has been running with this pump, with this condition, for the last 4 years! The pump shown is a replacement 40083, which is altogether different from the real McCoy.
          The process started when I investigated a possible lean condition, and premature power peak.
          I put a pressure gauge on, and measured 4psi @ idle, dropping to 3 psi @about 4000rpm.
          1963 Shop manual calls for 6.5-7.5 psi@ idle.
          I have a 1965, which uses a special pump (40083), and the 1965 supplement does not list the specs for the special pump. The pressures might be slightly higher than the 4657 pump used in 1963.
          I installed the original core 40083 which I rebuilt over last couple days, and now get 9 psi @ idle!
          I wonder if my original problem is solved?
          Some dyno testing is in order.
          Joe
          • Joe C.
            • August 31, 1999
            • 4598
            Here's How to Stake Valves in Place
            This is how I did it on the original 40083 core which I rebuilt a couple days ago:
            • Joe C.
              • August 31, 1999
              • 4598
              Re-Mounting the Diaphragm.....
              involves separating the old one:
              installing the new one:
                Originally posted by Joe Ciaravino (32899)
                I installed the original core 40083 which I rebuilt over last couple days, and now get a whopping 12.5 psi @ idle!
                I wonder if my original problem is solved.
                Joe
                Probably, but now you have a new one; ever see a needle and seat that will close against 12 psi?
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  I'd like to watch the test. Could be interesting.
                  Stu Fox
                  • Joe C.
                    • August 31, 1999
                    • 4598
                    John/Stu,
                    I used a different gauge, and edited my post above.
                    The pressure reading is 9psi using the pictured gauge.
