C1 Heater Motor - NCRS Discussion Boards
C1 Heater Motor
  • Pierre J.
    • July 31, 2000
    • 193
    C1 Heater Motor
    I am trying to install back in the car the heater assembly that belongs to my '57. The wiring diagram shows one brown wire coming from the switch to the motor. The motor that is with the heater assembly has four wires coming out of it: one green, one yellow, one red and one black.
    Do I have the wrong motor? it has - 3048F 12V - stamped at one end and sure looks like all other C1 heater motor that I have seen in the past including in my '60 and '56.
    Any help as how this motor, and the switch with three terminals, should be wired would be appreciated.
    Pierre 34410
  • Steven B.
    • June 30, 1982
    • 4018
    Re: C1 Heater Motor
    I need to go double check, but my December 1956 build '57 has the one brown wire.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Re: C1 Heater Motor
      Pierre, Steven's correct only one wire for the '56-7 heater motor. Not sure what you have with 3 leads present but for sure it's not a '56-7 heater fan. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
        Re: C1 Heater Motor
        My '57 #4275 also had one brown wire to the motor; I've never seen a Corvette heater blower with more than one wire.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          C1 Heater Motor
          It could be (if you want to use this motor on a temporary or permanent basis) you could just use what I believe would be the one "high speed" wire and let the dash heater reostat switch do its job. I do not know if one of these four is a ground. If so, you may have to use it too in case the motor is such that it requires a direct ground instead of using the motor housing itself as a ground. I'm doing some guessing here, of course. This post may self destruct in 60 seconds... Good Luck, Dennis
          • Pierre J.
            • July 31, 2000
            • 193
            Re: C1 Heater Motor
            Thanks all for your help. I searched the number on the end of the motor on Google and found out it came out of a bus or truck heater. The fit is absolutely perfect, even the squirrel cage. As suggested, I played with the wires and found a combination that works but I will be looking for one in Carlisle later this month. Thanks again.
            Pierre
