Cast iron Powerglide rear seal - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    Need to replace my rear seal on the Powerglide, slinging fluid... I was planning on jacking from rear end to tilt forward, how much fluid do I need to drain so it would drain out the back of the trans? Just need to get a big enough container if all 11 qts need to come out.
    Mike
    • 43290
    Re: Cast iron Powerglide rear seal
    Mike
    Mike----
    At least half of the total volume should stay in the torque converter.
    • Roy B.
      • February 1, 1975
      • 7044
      You may loose up to one quirt or jack the rear of the Corvette up.
      • Michael L.
        • July 31, 2005
        • 562
        Seal is in, old one was toast... Just an FYI, when putting one of these in while trans is in car, opt for a 12" piece of 2" diameter pipe to clear the X frame... I went 6" and it was a bit tougher than it should have been.
