Early vs. late '66 BB fuel pump - NCRS Discussion Boards
  • Steven S.
    • August 29, 2007
    • 571
    What exactly changed with the BB fuel pumps in '66?
    Steve
    • 43248
    Re: Early vs. late '66 BB fuel pump
    Steve
    Steve-----
    Primarily, it had to do with the configuration of the nipple of the fuel pump inlet chamber. Early 40366 had a welded-on, curved tube; later used a "welded"-on, machined brass fitting.
    • Cecil L.
      • May 31, 1980
      • 449
      Any rough idea about when the change-over took place?
      • Steven S.
        • August 29, 2007
        • 571
        Steve-----
        So it sounds like they would be interchangeable as far as function goes?
        February 1966 from what I have read was the approx. changeover point.
        Steve
          • 43248
          Steve
          Steve-----
          100% interchangeable as far as functionality is concerned. In fact, the AC type number did not change when the inlet fitting changed. So, as far as GM was concerned, they were the same pump.
          • Steven S.
            • August 29, 2007
            • 571
            Thanks Joe
