C1 Wiper Switch - NCRS Discussion Boards
C1 Wiper Switch
  • Richard H.
    • March 1, 1985
    • 241
    C1 Wiper Switch
    The wiper switch I removed from the pod is a small rectangular unit with two electrical clips protruding from the bottom. The shaft that goes through the pod opening is threaded at the end and moves in and out. Am I correct in assuming that this is the proper unit for a nonwasher system? This washer switch is obviously completely different from the washer switch with cables. If correct, does the knob screw-on to the shaft? Thanks.
  • Joe M.
    • April 30, 1990
    • 1342
    Re: C1 Wiper Switch
    It is difficult to provide an answer without knowing what year you are referring to.
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: C1 Wiper Switch
      I believe that on all C1s the wiper knob is fastened to the shaft with a slotted set screw.
      There are no electrical connections on the wiper switch under the dash. The switch is in the wiper motor assembly.
      Bruce B.
      • Richard H.
        • March 1, 1985
        • 241
        Re: C1 Wiper Switch
        I determined the switch was not original. Thanks.
