Hi; I'm finishing up my hardtop and putting in a new rear plastic window. It's a Plasticon (Oval Window). The original rubber that goes around the plastic has a white lock strip. Does the slotted side go to the inside or the out side of the hardtop? Looks as if it could go either way. Thanks Bob
53-55 Hardtop
Re: 53-55 Hardtop
Robert
Where did you get the new back window and rubber? Did you refinish the headliner and if so how?
Joe- Top
Re: 53-55 Hardtop
I have an original plasticon top that I will probably restore and will need a back window and headliner.
Can you advise where you got your restoration hardtop parts.
Did you paint your top and if so with what type of paint?
Joe- Top
Re: 53-55 Hardtop
I had the original rubber. I made a template from the window opening using heavy cardboard. and cut the plastic to fit. Took quite a while to get it right. I talked to a guy back in Indiana who told me how to make the template, cut the plastic with a hot knife and how to put the rubber and window in the top using a piece of wire and sliding it around. (Mine is not in yet) The headliner is going to be leather Like Roy's. Paint is 2 part epoxy Pollo White
I'm taking Pic's as I go. Will post when finished....Thanks Bob- Top
Re: 53-55 Hardtop
JC whitney among others sells the weatherstrip. Any upholstery shop can provide the lining material. I would paint the top with whatever your body is painted with, for the best match. I had a boat shop make my window.- Top
