clock - NCRS Discussion Boards
clock
+ More Options
Posts
  • Sal R.
    • December 10, 2007
    • 160
    clock
    I have a 65 and the clock does not work,does any one out there know where I can sent it for repair.
    Thank You
    Sal R
  • Harry S.
    • July 31, 2002
    • 5315
    Re: clock
    Sal, there are many places and everyone has their favorite. Try Joe Ray, just let him know if you want just mechanical or mechanical and cosmetic. He is a long time member and can be reached at:
    http://joerayparts.com/
    Harry
    • Sal R.
      • December 10, 2007
      • 160
      Re: clock
      Thank you so much Harry
      • John F.
        • March 23, 2008
        • 2409
        Re: clock
        I used clockwks.com. Outstanding service & good turnaround time. John
        • David D.
          • January 1, 2005
          • 416
          Re: clock
          Thank You
          Sal R
          I used Harrison Speedometer and it turned out fantastic. Reasonably priced and Bill was great to work with. gldnkngt@comcast.net. www.harrisonspeedometer.com 561-676-3099.
          David
          • Anthony G.
            • February 1, 2006
            • 50
            Re: clock
            Does anybody know of a way to bench test a C2 clock to make sure the problem is the clock and not the wiring?
            Tony Gray
            York, PA
            66 327/350 Convert.
            AACA Senior Award Winner Hershey 2009
            • Stephen L.
              • May 31, 1984
              • 3158
              Re: clock
              Connect the clock to a 12vdc battery, and let it run for awhile to see if it'll continue after a few days. Many times they run for a few "wind cycles" then quit.
              Connect the pole on the rear of the clock to + and the case to -.
              These clocks are mechanical, and are wound every few minutes by the battery. Typically the "electrical contacts" in the winding circuit are burned/corroded causing the clock to not wind.
              • Anthony G.
                • February 1, 2006
                • 50
                Re: clock
                Thanks Steve. I'll give it a shot. Appreciate the quick response.
                Tony
                Tony Gray
                York, PA
                66 327/350 Convert.
                • William D.
                  • April 1, 1993
                  • 101
                  Re: clock
                  I used D & M restorations in Greenville,SC for my 65 clock. Fast turn around clock works great.
                  Bill
                  1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
                  1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
                  • Stephen L.
                    • May 31, 1984
                    • 3158
                    Re: clock
                    I also used D&M in Greenville. Just happens that I also live in the Greenville area and have been to their shop. They do instrument repair on many types of cars.. Corvette being one of them. They do a lot of work on vintage classics. Their work is excellent.
                    Steve
