GM Number on Back of 71 Instrument Console Gauge Bezel - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    Does anyone know what the GM number is on the back of the instrument console gauge bezel for a 1971. Thanks Paul
    • 43246
    Re: GM Number on Back of 71 Instrument Console Gauge Bezel
    Paul-----
    If you're talking about the number on a paper label affixed to the rear of the cluster assembly, it's the part number for that assembly. This is NOT a SERVICE part number and won't be found in a P&A catalog since the assembly was never available in SERVICE. For a 1971, I would expect the number to be GM #6491003.
    • Paul C.
      • November 12, 2007
      • 511
      What would 6491171-69 & 6497585-72 indicate? Would they past judging on a 1971? Thanks Paul
        • 11659
        Seeing as no one in the NCRS is small enough or flexible enough to even think about looking at those labels, I think you'll do just fine.
        Patrick
          • 43246
          Paul-----
          Are these numbers printed on a paper tag or are they otherwise?
            • 43246
            Patrick
            Patrick----
            Beware! Proctoscopes are coming.
              • 11659
              Patrick----
              Joe,
              We already own two, and I'm not about to bring one out on the judging field.
              Patrick
              • Paul C.
                • November 12, 2007
                • 511
                The numbers 6497585-72 (top on bezel) and 6491171-69 (bottom of bezel) are stamped in the metal on the lower end. I just want to make sure it is th same as the 1971 bezel. I really appreciate your help.
