On the Road to National - NCRS Discussion Boards
  • Rick A.
    • July 31, 2002
    • 2147
    Will be driving my 1963 Z06 on the NCRS Road Tour to St Charles - Eastern leg starts in Front Royal, VA tomorrow morning - am headed off to join the tour around 1300 this afternoon - will spend the evening in Front Royal and we take off for a 6-day drive ending in St Charles around 1500 on Sunday - National meet then commences on July 21st and runs through July 24th - am hoping to score a Duntov with my Lady
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
  • Roy V.
    • April 8, 2008
    • 301
    Re: On the Road to National
    best wishes for a great trip, please post updates when you can !
    1972 LT-1 Elkhart Green Coupe
    • Gary B.
      • September 30, 1987
      • 305
      Rick: See you in Canal Winchester. Eh.
      • Rick A.
        • July 31, 2002
        • 2147
        Gary,
        look forward to meeting you!
        got to the hotel in Front Royal about 1500 hours, after about a 2-hour drive from my house - tried to keep speedo steady at 70 MPH; tach at 3300 RPM; oil pressure held steady at about 60 pounds; temp at about 170 degrees; Lady was chomping at the bit! (VBG) - 101 miles from house to hotel and topped off gas tank with 5.6 gallons, so didn't do too bad on mileage!
        there is a 1967 black/red stinger 427 and a 1958 also here at the hotel as I type this - see all @ National!
        will post more later
        Rick Aleshire
        • Brian M.
          • February 1, 1997
          • 1839
          Rick, sounds like busn as usual for your LBC . I wish I signed up for this Road Tour as the second owner of my car 1972 thru 1984 is suposed to be at the National. If you run inro Jim McMillan say hello for me. Good Luck.
          • Rick A.
            • July 31, 2002
            • 2147
            Brian,
            will keep my eyes and ears open
            Rick Aleshire
            • Greg P.
              1961-62 Team Leader
              • March 1, 1985
              • 55
              rick good luck and be safe and stay away from the Mark while driving!
              • John W.
                Administrator
                • November 1, 1974
                • 5087
                Wife and I and the '62 will be meeting the tour at Zarika's Garage tomorrow afternoon. Looking forward to meeting all of the Road Tour participants for a great ride to St. Charles.
                Look me up and introduce yourself. Love to meet all of the Tech Board participants that I can.
                Administrator
                www.ncrs.org
                • John D.
                  • December 1, 1979
                  • 5507
                  Originally posted by Rick Aleshire (38392)
                  Brian,
                  Ricky,How is the real deal tar top holding up?. Best of luck on getting your Duntov. John D.
                  • James W.
                    • December 1, 1990
                    • 2657
                    I'm leaving Saturday morning and joining up with Mike Doty as one of only two Northwest Road Tour Participants. Should be in Rolla by Saturday afternoon.
                    James West
                    Omaha, NE.
                    • Rick A.
                      • July 31, 2002
                      • 2147
                      JD,
                      battery is holding up well - Lady fires right up every morning and just a hint of acid spray through the caps - got the maintenance free battery in the passenger foot well - averaging almost 18 mpg for the trip so far - got me as the leader for the C1/C2 cars, so got to drive sensibly, instead of speeding along with all the new Z06's (VBG)
                      Rick Aleshire
                      • Rick A.
                        • July 31, 2002
                        • 2147
                        James,
                        look forward to seeing you on the "Last Night Out"
                        Rick Aleshire
                        • James W.
                          • December 1, 1990
                          • 2657
                          James,
                          Rick,
                          I hope your trip is going well. I went out last night and put the car on the hoist to check the suspension bolts & nuts, drive shaft & half shaft connections, rear differential and transmission oil levels. I then checked the spark plugs, the remaining fluid levels, belts, hoses and lights & signals. Tonight is road test night a quick clean up and then doing a spare parts and tools inventory. When driving a C2 you just never know what might happen, I have enough spare parts, water pump, alternator, fuel pump, coil, dist cap and rotor, points/condenser, wheel bearings, belts, hoses, etc that I have carried on past road tours and thankfully the only thing I have had to replace was a fuel pump at the Bowling Green Regional meet in 2005.
                          See you in Rolla I will be driving a red 1964 convertible with a white top, knock-off wheels and Nebraska historical plates. I attached a picture of the car taken at the 2005 National Meet in Park City, Utah.
                          James West
