Delco Shock ID - NCRS Discussion Boards
Delco Shock ID
  • Donald T.
    • September 30, 2002
    • 1319
    Delco Shock ID
    Can anyone identify these rear shocks? They are Delco shocks and look like the same configuration as 63-82 Corvette. However, I cannot find any reference for the Delco part number stamped on them of 4975425. The date codes indicate they were manufactured in 1976.
    Thanks!
    Don
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Delco Shock ID
    Donald;
    Let's send you back for another look see.
    Stu Fox
      • 43281
      Re: Delco Shock ID
      Thanks!
      Don
      Don-----
      I can't ID most on-shock part numbers. These are Delco Chassis part numbers which means they can be applicable to any GM car or truck. That represents a huge "universe" of possible applications. There are other shock absorbers that, configuration-wise, are similar or identical to Corvette.
      All that being said, I don't think these are Corvette shocks. Many (but not all) of the Corvette on-shock part numbers I have reference for and I don't find this number. Still, it is possible they are Corvette. What color are they painted?
      • Donald T.
        • 1319
        Re: Delco Shock ID
        Don-----
        Thanks Joe. They are painted the same color as the originals for my 65. I also compared them side by side and they have the same configuration as well. I'm thinking you are correct that they are not for Corvette. I don't have any history other than I received them along with other Corvette parts, but that means little.
        Thanks!
