65 tire that will fit in my spare tire area ? - NCRS Discussion Boards
  • Mark H.
    • November 1, 2005
    • 112
    Anyone know where I can find - hopefully in So Cal - a tire that will fit in my spare tire location ? I have a 195/70-15 in there now and it won't allow the door to close all the way. I guess a could go to Paragon or others, but if anyone has other options I'd like to hear them.
    Mark
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 65 tire that will fit in my spare tire area ?
    Hi Mark,
    Try the longer front hinge bolts for the lid like those originally intended for the redline option for the '67's.
    And/or a 60 series tire or 50, you have options.
    HaND
    • Wayne P.
      • August 31, 1975
      • 1025
      Sorry to disagree, but you do NOT want a wider tire.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Mark, if you looking for a radial size - am using a 185x65 R16 with the longer bolts as Mike pointed out. Closes to within 1/4 of an inch. So far in the last ten years of the '64 as a driver it's not been a problem with road dirt, etc. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Albert P.
          • April 1, 2006
          • 205
          I used a P185 60 R15, fits perfectly in the tub
          • David T.
            • August 31, 1995
            • 51
            If you're looking for a radial tire and don't care if the wheel is stock, try a T155/90/D16 mini spare (donut spare). They are used on newer GM S10 pickups and Blazers. Fits in the well, bolts up nicely, and is the same diameter as a 205/75/15 radial. Should be cheap ($10-$20) at your local auto recycling center.
            Dave T.
