1961 convertible top - NCRS Discussion Boards
  • Ernest C.
    • July 31, 1991
    • 115
    Can someone please describe the length of the vinyl welt above the back window. I've seen cars where the chrome tips are in different positions.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1961 convertible top
    Should be at the vary end of the bow where you can still screw it on.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Ernest, the 61-2 JM doesn't give a specific length. However, it should be approximately 6-7 inches from the front to back seam. There should be a hole in the frame where the screws were originally screwed in. I use a tip of forefinger to tip of thumb rule to check the spacing from the seam. Hope this helps. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Ernest C.
        • July 31, 1991
        • 115
        Thanks for the help.
        • Bruce B.
          • May 31, 1996
          • 2930
          I measured the welt on a 62 top and it measured 47 1/2 inches from the center of the left screw to the center of the right screw.
          I also measured the length of a welt that was removed from a 62 top I have and it measured 44 3/4 inches total length.
          Hope this info helps.
          Bruce B.
