Re: 1962 Gas Gauge Puzzle
If you're going to run a temporary ground for test purposes, going directly to the battery Neg post is preferred. Why?
You need to insure you have a good 'bite' when grounding to the chassis. Things like paint & oxidation can cloud the issue, that's unless you want to drill a fresh hole in the chassis + use a clean/new screw and washer...
Personally, I'd wait on the outcome of your temporary test that routes directly to the battery negative terminal!
I think I should install the extra ground at a minimum.
