Need your advise as I am stumped.
Symptoms:
Can anyone please help...I hate to go in there and replace the sending unit not knowing if that's the problem??????
Thanks much.
Symptoms:
- Cold engine, ignition on, gas gauge doesn't register.
- Start motor, runs 30 seconds - 2 minutes, gas gauge registers perfectly.
- Hot engine, ignition on, gas gauge registers perfectly.
- Wire connections tight on gauge
- Removed brown wire from connector behind driver kick panel, cleaned, reinstalled, checked other connections in adjacent block
Thanks much.
 1962 Gas Gauge Puzzle
