66 Standard Steering Wheel Finish - NCRS Discussion Boards
  • William G.
    • January 1, 1988
    • 220
    My 66 steering wheel is the standard molded plastic grained wheel. It is in perfect condition but it appears that the outer shiny skin is worn off, and the wheel is always a bit sticky especially in the warm weather no matter what I use to clean it. Is there a good finish to restore this wheel? Like a couple of coats of two part clear urethane paint? I will appreciate any suggestions. Thanks to all.
  • Ridge K.
    • May 31, 2006
    • 1018
    Re: 66 Standard Steering Wheel Finish
    here's a tip I pulled off another classic car web blog. I can't vouch for the results, but have had very good luck with 3M products in the past. Hope this is helpful. Ridge.
    re: Gm Steering Wheel Sticky
    I was driving a 76 El Camino with the nastiest stickyboo wheel ever! I tried lots of stuff with poor results and much labor.
    Then I got some 3M Adhesive remover (don't remember the number). Had that honey-coated creepy wheel clean and tack free in just an hour or two. Drove the truck for another 2 years and never had to repeat the application even during the summer heat here in Houston.
    • William G.
      • January 1, 1988
      • 220
      I have a can of 3M adhesive remover and already tried it, but will try again . Thanks!
      • Wayne W.
        • April 30, 1982
        • 3605
        Sticky wheel is commonly associated with the black later wheels. It is not a common problem with midyears. I would clean it with lacquer thinner and coat it with clear urethane.
