Tachometer dates and numbers - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    I have a tachometer that has a date JU1 21 6A60569. Thease numbers are on the back of the face with an ink stamp and are hard to read so a number could be wrong. This is in a 1971. I could not find any information in the AIM or any books I have as to how to read the date and what the part number was used for.
    Lyle
    • 43272
    Re: Tachometer dates and numbers
    "6A60569" does not "compute" as a GM part number. However, I strongly suspect that the "6A6" part of the number is actually "646". The "0569" does not "compute", either, as the last 4 digits of any part number used for a 1971 tach. So, I suspect the last 4 digits are actually "9566" making the number 6469566. If so, this is the tachometer used for 1969-71 Corvettes with base engine. The tach redline and pale green numerals may further confirm that.
      • 15630
      Try JU (June) 1, 71. Does that date work for your car? There is usually a paper tag with two or three letters on it that is the broadcast code for the instrument assembly. That won't help much, since I know of no compilation of those codes.
      • Harmon C.
        • August 31, 1994
        • 3228
        Joe
        The red line is 6500. I checked the ink stamp again and 6469569 is more what I see. The last number is a small zero and the tail is not up but looks more like it is a 9.The first six numbers are what you thought they were 646956. It is pale green numbers.
        Lyle
        • Harmon C.
          • August 31, 1994
          • 3228
          June 1 71 would work as the build date is K-23 June 23 1971. The paper tag is missing in action. The stamp is JU1 double space 21.
          Lyle
            • 43272
            Joe
            Lyle----
            GM #6469569 is the tach used for 1970 Corvettes with LT-1. Although I don't show it for 1971 Corvettes, I strongly suspect it was the unit used for 1971 LT-1, too. It was not used for 1972 LT-1, though.
            • Harmon C.
              • August 31, 1994
              • 3228
              Thanks Terry and Joe it looks like I have the correct part.
              Lyle
