Neutral safety switch - NCRS Discussion Boards
  • Gary P.
    • May 31, 2005
    • 104
    I have a 63 FI 4 speed, Is there a switch that came on 4 speeds so the car would not start in gear? Did they only come on automatics? or only on some cars? Is it also called reverse lock out? I'm lost, can't seem to find anything on this. Gary.
  • Robert R.
    • May 31, 1975
    • 358
    Re: Neutral safety switch
    Gary,
    Usually the Neutral Safety Switch is for automatic equipped cars.
    As to the Reverse Lock out, if you have the stock shifter, it should have a "T" handle below the Shifter ball. When lifted, it will allow you to move the shifter to reverse gear, thus preventing accidentally going into reverse while moving through the forward gears.
    Bob
    • Kevin G.
      • February 1, 2005
      • 1076
      The neutral saftey switch on my 72 four speed will not allow the motor to crank without depressing the clutch petal and is located on upper leg of the clutch linkage. The reverse lockout has a cable connected to the reverse lever on the trans to the steering column, with the shifter in reverse it locks the steering column and allows you to remove the key. Not sure if your 63 would be the same, maybe someone else can help?
      Kevin
      • Edward B.
        • January 1, 1988
        • 537
        When did Chevrolet first introduce the clutch operated safety switch: On passenger cars?; on trucks?; on Corvettes?
          • 43219
          Edward-----
          For Corvettes, the neutral start safety switch for manual transmission cars was first used for the 1969 model year. For most other Chevrolet cars, I believe it started for the 1970 model year.
          • Edward B.
            • January 1, 1988
            • 537
            Thanks, Joe. I first remember it in the mid 70s, but I was never much on brand new cars so there would have been some time lag.
            • William C.
              • May 31, 1975
              • 6037
              Actually I believe it was a Federal requirement, 1969 for all GM cars.
              Bill Clupper #618
              • Robert R.
                • May 31, 1975
                • 358
                Bill,
                That would be correct as all ignition switches moved from the dash to the steering column that year for GM cars.
                Gary,
                Did this help answer your original question?
                I should have noted that in my first response for the neutral safety switch would be for '68 and older models. And that as to the reverse lockout would be for 4spds with the stock shifter.
                Bob
                • Gary P.
                  • May 31, 2005
                  • 104
                  Question answered. Thanks everybody.
