1966- proper place to bolt negative cable - NCRS Discussion Boards
  • Jim D.
    • December 15, 2006
    • 39
    My negative cable was on the the starter bolt, I don't believe that is correct. I thought more like one of the bell housing bolts ? I know you guys can tell me the proper place. 66 327/350 hp vert.
    • 43295
    Re: 1966- proper place to bolt negative cable
    Jim-----
    I believe the short starter attaching bolt is the correct attachment point for the battery ground cable for your application UNLESS you also have C-60. In that case, the ground cable attaches to one of the bellhousing bolts.
    • Jim D.
      • December 15, 2006
      • 39
      Jim-----
      Not sure what a C60 is, but i guess it was in the correct location thank you.
      • Larry M.
        • January 1, 1992
        • 2703
        C60 is factory air conditioning.
        Larry
        • Jim D.
          • December 15, 2006
          • 39
          Thanks Larry, learn something new every dat here.
          • Nicholas V.
            Infrequent User
            • March 1, 2001
            • 6
            As a follow up, I have a 67 327/350 without A/C. My negative battery cable is attached on one of the bellhousing bolts and I need to replace it. Is this correct or should it be on the starter bolt? Thanks!
            Nick
