Strap Identification - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    I found these straps in a box and have no idea where they belong..
    My guess is they have something to do the soft top?
    Any help appreciated..
    Re: Strap Identification
    A set of reproduction rear deck lid tabs?
    • Joe P.
      • October 4, 2007
      • 209
      Did some more digging... Found it..
      Convertible top frame hold down compression strap kit, 8 1/2" long, Black. These straps hold the top frame together tightly when folded down.
      Now.. where are they attached? Any pictures would be welcomed..
      THanks..
      • Joe P.
        • October 4, 2007
        • 209
        is this what you mean?
        • Richard T.
          • February 1, 1979
          • 858
          Joe,
          Regarding the black "footman Straps", The end with the male snap that has a screw running through it will screw into the rear bow, you should find a hole on the inside of the bow just after the curve. The other end with the female snap should snap over a male snap mounted on the soft top frame just behind the rear edge of the side window. The ST-12 shows how they're used. I hope that I made it clear but if not check out the ST-12. Rich
          • Joe P.
            • October 4, 2007
            • 209
            Originally posted by Richard Thomas (2276)
            Joe,
            Perfectly clear.. thanks..
            I couldn't find anythng in the assembly manual, and my ST-12 was ordered last week and is on its way now.. I will be glad when it arrives.
            Joe
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12746
              Here it is:
              This is how it is attached:
              This is where it snaps into:
              Rob.
              NCRS Software Developer
              • Joe P.
                • October 4, 2007
                • 209
                Rob, thanks again..
                Joe.
