'61 Carter Carb - NCRS Discussion Boards
'61 Carter Carb
  • Richard P.
    • July 31, 2001
    • 173
    '61 Carter Carb
    I just received a newly rebuilt carb from a vendor for my '61, 283/230, 12/7/60 build. There are a couple of things I can't figure out. One is that on the back of the carb (distributor side) of the thick black mounting plate there is a threaded female inlet that I am not certain what is is for. Secondly, I have tried to check the numbers against the NCRS Judging book. The Airhorn number matches up (6-1396), but the number on the Throttle plate is 0-1241. If I am reading the book correctly it should be 0-1343. Is there somewhere else I need to be looking for numbers? Any thoughts or comments would be appreciated.
  • Bob B.
    • March 1, 2003
    • 831
    Re: '61 Carter Carb
    Richard,
    The hole is for a vacuum fitting. Your car should have the hollow left rear carburetor stud where your vacuum line goes, so you can use a hex plug to fill the hole.
    I'm not sure what an 0-1241 goes to, but it doesn't seem to be a Corvette application and certainly not for your car. If the rebuilt carb was yours, maybe it already had a replacement piece on it. If you bought it and they said it was the right one for your car, they should correct that.
    Bob
    • Richard P.
      • July 31, 2001
      • 173
      Re: '61 Carter Carb
      Bob:
      I was afraid of that. It was not a rebuild of mine. I bought it from Alf @ Chicago Corvettes, who looks like bought it from Custom Rebult Carbs in NJ. I gave them all of the specs for my car but it looks like they missed it. I sure hope they stand behind it.
      • William C.
        • May 31, 1975
        • 6037
        Re: '61 Carter Carb
        Good luck, It might be possible to give more information if you had stated the part number of the carb you thought you were buying.
        Bill Clupper #618
          Re: '61 Carter Carb
          You're reading the book + your carb wrong. The BODY cast number for a '61 Carter 3059S is either 0-1343 or 0-1517. Don't be lookin' at the throttle plate when the JG book says body...
