67 breaking up @ 4200 ?? - NCRS Discussion Boards
  • Fred Y.
    • April 30, 2000
    • 319
    I just completed my yearly Spring tune-up of my 67 400HP coupe. For the last 2 years,I've noticed it sometimes breaks up when I "excercise it" at the higher RPM's-----this bugs me as I like everything to work just right.Last yr. I tried a 30K volt coil,( as I figured it might help with the poor gas we have in Ct.) along with the lectic limited ignition I have in it with a 50/50 110 leaded/93 unleaded gas mix.I use A/C R4 platinum plugs.The carbs are tuned right & were rebuilt some 6 yrs ago----they're OK! I did find out that the distributor needed a rebuild & had it COMPLETELY DONE.She has never idled better! I had a friend who is more than capable helping me on this & the next issue we summized was fuel pump-----replaced it!!We next looked around for broken or damaged wires both in the engine compartment & under the dash ---everything looked fine.I replaced the fuel tank some 5 yrs ago----spotless---fuel flows fine!Changed the dist. cap---changed the rotor! It still breaks up at 4200 RPM as if it were going FLAT---it sounds like a tractor with a jake brake applied----driving me nuts! Below 4200 it "SINGS" My only guess is the wires----but they are approx. 6yrs old---look fine---electic limited original Pacard wires----I see no arcing at night!!---
    I could sure use some input,because I am stumped!!
    Go back & install the original coil & work my way backwards??
    Thankyou for your help!
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 breaking up @ 4200 ??
    take it out and run it hard several times to the problem RPM point. shut of the ignition,coast to the side of the road,pull a spark plug. if the plug is clean and white you have a fuel problem and if it is dark you have ignition problem.
    • Thomas H.
      • August 31, 2005
      • 1061
      Fuel filter?
      Tom
      2007 Z06, Lemans Blue
      • Fred Y.
        • April 30, 2000
        • 319
        Thanks----will try tomorrow !
        • Fred Y.
          • April 30, 2000
          • 319
          Members, this note is long over due , but better late than never.The whole problem with my cars breaking up was the wires! I purchased a 100' spool of 7mm wire along with new clips and now on my 2nd yr. using them. Best yet , I was able to slip the old wires from the braided shielding ( after I cleaned it with a rag & simple green) & slip them back through. The boots were AOK still. She now runs perfect at all RPM ranges.
          • Timothy B.
            • April 30, 1983
            • 5196
            Frederick,
            If you need to replace them in the future consider the NAPA Belden 7mm premium wire set, it's a very top of the line product and Beldon makes many different wire cable products so they are not new to wires.
            I just went through this in July with my 67 it started to hesitate cruising in forth and throttling up. The problem was a dirty #8 spark plug caused by a wire that could not deliver the necessary voltage to lite a lean mixture. I think the wire was approx 30-32" long and it's ohm reading was 11000+- ohms. The new Belden long wires that go to the #1-2 & 3 plugs checked at 11000 ohms for comparision.
