I just completed my yearly Spring tune-up of my 67 400HP coupe. For the last 2 years,I've noticed it sometimes breaks up when I "excercise it" at the higher RPM's-----this bugs me as I like everything to work just right.Last yr. I tried a 30K volt coil,( as I figured it might help with the poor gas we have in Ct.) along with the lectic limited ignition I have in it with a 50/50 110 leaded/93 unleaded gas mix.I use A/C R4 platinum plugs.The carbs are tuned right & were rebuilt some 6 yrs ago----they're OK! I did find out that the distributor needed a rebuild & had it COMPLETELY DONE.She has never idled better! I had a friend who is more than capable helping me on this & the next issue we summized was fuel pump-----replaced it!!We next looked around for broken or damaged wires both in the engine compartment & under the dash ---everything looked fine.I replaced the fuel tank some 5 yrs ago----spotless---fuel flows fine!Changed the dist. cap---changed the rotor! It still breaks up at 4200 RPM as if it were going FLAT---it sounds like a tractor with a jake brake applied----driving me nuts! Below 4200 it "SINGS" My only guess is the wires----but they are approx. 6yrs old---look fine---electic limited original Pacard wires----I see no arcing at night!!---
I could sure use some input,because I am stumped!!
Go back & install the original coil & work my way backwards??
Thankyou for your help!
