I could use some hits or tips on aligning the body with the frame. I have the 1/2" rods that go through the door sill and frame rail in place but there is still a lot of movement allowed.
The drivers side muffler touches on the lower fender lip even though it's the correct distance from the spare tire tub.
How can you determine how high to set the front frame support that the rad support sits on? If it''s too high or too low won't it put undue stress on the fiberglass and cause cracks around the hood surround?
Thanks.
Thanks.
