Rear spindle inner bearing seal - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    Any special tools/procedure required to replace rear spindle inner bearing seal and dust deflector while on car? Thanks.
    • 43285
    Re: Rear spindle inner bearing seal
    Albert-----
    Yes, to remove the inner bearing requires, basically, the same tools used to remove the spindle are required. In fact, if you're going to replace the inner bearing, you might as well overhaul the whole assembly and replace the outer bearing, too.
    • Dick W.
      • 10483
      If you are just talking about the seal, it is not a major problem. BUT if the seal is leaking grease smart money would say that the bearing is also bad. I would seriously consider overhauling the assembly, either by sending it out or doing it yourself if you have the tools and are inclined to spend a long Saturday afternoon working
      Dick Whittington
