1971 Big Block Engine Mount Gap???? - NCRS Discussion Boards
  • Greg E.
    • June 4, 2008
    • 27
    Hi All
    There is a gap between the chassis horn and the engine mount on my 1971, 454, LS5, 4-Sp.
    The new engine mounts are the same as the old ones i took off, but there is a gap of about 1/8 between each side of the mount when the bolts are tight, if a tighten the bolt up so the spacers that a welded on the inside to the engine mount are hard against the horn it will buckle the engine mount.
    The old engine mounts look like they were tightened so the spacers would be hard against the horn and tightening the bolt has bent the sides of the engine mount in till the spacers have touched the chassis horn.
    QUESTION
    Is this gap normal????, do i tighten the bolt up till it's tight and then stop, or do i keep tightening the bolt till the spacers touch the horn????
    Kind Regards
    Greg...
    Australia
  • Michael M.
    • February 15, 2007
    • 455
    Re: 1971 Big Block Engine Mount Gap????
    Can you post a picture of your situation?
    • Bill C.
      • July 15, 2007
      • 904
      The aftermarket/repop ones are a little to big.
      I had the same isssue going back when I was doing my resto.
      The only way I could fix this was to use NOS GM ones. They have a spacer welded on each side and fit exact.
      You could make a spacer and insert it between the mount and the frame on each side. Just paint them black and they will blend in.
      IMHO - it is not a good idea to compress the mounts so they are buckled.
      You can find the NOS ones on ebay - set is running around $200 or check the monthly newsletter for NCRS.
      Hope this helps ...
      • Greg E.
        • June 4, 2008
        • 27
        Gday Michael
        I'm so sorry for taking this long to reply to your message, thank you for your help, but i have sorted my problem out.
        Again i apologise for not replying sooner!!!!!!!!
        Kind regards mate...
        Greg...
        Australia.
        • Greg E.
          • June 4, 2008
          • 27
          Hope this helps ...
          Gday Bill
          I'm so very sorry for taking this long to reply, thank you for your help, your advice has fixed my probem.
          Again Bill, i apologise for the delay with my many thanks!!!!!!
          Greg...
          Australia.
          • Michael M.
            • February 15, 2007
            • 455
            No problem Greg, I kept up and saw that Bill responded.
            • Michael M.
              • February 15, 2007
              • 455
