crankcase ventilator - NCRS Discussion Boards
+ More Options
Posts
  • Tom K.
    • August 31, 1989
    • 28
    i recently removed the crank case ventilator tube on my 65/300hp, is the filter inside still available and is there anything inside the orifice in the block?
    • 43290
    Re: crankcase ventilator
    Tom-----
    I don't know of any filter that was ever used in connection with the crankcase ventilator tube or crankcase ventilation system on a 1965.
    There is nothing inside the orifice in the block. However, there is a crankcase ventilator oil separator mounted in the lifter valley and to which the ventilator tube effectively connects.
      Here's the oil separator can in the lifter valley - it just has a couple of baffles inside it; as Joe noted, there are no filters of any kind in the crankcase vent hole in the block or in the adapter tube that connects to the air cleaner base.
      • Tom K.
        • August 31, 1989
        • 28
        inside the vertical portion of the tube assembly i found what looks like a fine mesh brillo pad, also in the opening, floating in oil, was a nylon grommet. i thought it might be a gasket but it does'nt fit any opening.
        • Tom K.
          • August 31, 1989
          • 28
          thanks guys, i'm not with my car now but i'll check again next week
