Stabilizer Bar Bushings - NCRS Discussion Boards
  • Bob S.
    • August 12, 2007
    • 185
    I have just received my new front stabilizer bar bushings (poly) for my '59. When I install the bushing in the U-bracket and set it on top of the stabilizer bar spacer there is a 5/16" gap between the flanges. Is this correct? Do I just pull it down with the bolts? This seems like it would put the bar in a bind.
    The U-bracket and spacer are original and the bushings are for use in the original brackets.
    Also, when installing the bar the ends have a slight angle to them. Is the angle supposed to go up or down? I am guessing down for proper angle for the stabilizer link. I can't tell by looking at the AIM.
    Thoughts?
  • David B.
    • July 31, 2004
    • 330
    Re: Stabilizer Bar Bushings
    Bob,
    The stabilizer bar end bends go up. If they are reversed, the stab links cannot be installed correctly. I attached a picture of one with the bar in upside down, when I got it. I since corrected it and also installed poly bushings. I don't remember how big the gap had to compress, but there was some compression needed. I think it will be fine if you tighten it down. The poly bushings make a nice upgrade in handling.
    Dave
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
    • Bob S.
      • August 12, 2007
      • 185
      Thanks David. I will be pulling the body back off hopefully over the 4th of July to finish everything underneath and I will try just cranking it down.
      Sully
