I have just received my new front stabilizer bar bushings (poly) for my '59. When I install the bushing in the U-bracket and set it on top of the stabilizer bar spacer there is a 5/16" gap between the flanges. Is this correct? Do I just pull it down with the bolts? This seems like it would put the bar in a bind.
The U-bracket and spacer are original and the bushings are for use in the original brackets.
Also, when installing the bar the ends have a slight angle to them. Is the angle supposed to go up or down? I am guessing down for proper angle for the stabilizer link. I can't tell by looking at the AIM.
Thoughts?
Thoughts?
