65' 396/425 Spark Plugs
Re: 65' 396/425 Spark Plugs
The one from K&B looks completely different - must be another new entry.- Top
Well I found out that my problem was the reproduction #210 coil all along. This made the car run crappy after it was at operation temp and died at idle. The problem was compounded when I replaced the new K & B T.I. module with my original one and the car started right up. So, I immediately suspected the module. However, the car continued to run poorly and I then hooked up my #207 service replacement coil and the car ran 95% better. So, the T.I. module was not the problem afterall but the reproduction coil was. I have asked around and the opinion is that this coil is not the correct amp for the car. My local corvette guru knew this all along.- Top
