Knock Outs ? - NCRS Discussion Boards
Knock Outs ?
  • Noel K.
    • October 31, 2004
    • 84
    Knock Outs ?
    Trying again for a top flight - while reviewing my last judging sheet I found the following comment under the "Mirrors & Door Handles" lines in the Exterior Section for my '65:
    Door Handles, key lock bezel & gasket: No gasket on left & right key lock. No knock outs.
    What is meant by no knock outs ? Are they speaking of the keys ? If so, is it a simple fix of punching out the knock outs on the keys ? The keys I have were purchased from Jesser at Carlisle two years ago. Supposed to be the correct key blanks.
    Thanks in advance
    Noel
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Knock Outs ?
    I think you should have ask the judges but appears to be an incorrect statement with what you have said if you bought keys with knockouts.
    Lyle
      • November 30, 1989
      • 11616
      Re: Knock Outs ?
      As Lyle states, if your keys have knockouts still in place, either the judges forgot to ask to see them or you forgot to correct them when they took off the point.
      If you don't have knockouts, then you're supposed to have them.
      Patrick
      • Bob D.
        NCRS Shipping Data Report Manager
        • April 30, 1996
        • 787
        Re: Knock Outs ?
        Noel Sounds lilke the judges missed the fact the knock outs are still in the keys. Better you should point that out to them the next time you have your car judged.
          Director Region V
          • August 31, 1994
          • 1463
          Re: Knock Outs ?
          Noel,
          not only are the "Knock-outs" to remain in place in the keys, they should have the key codes stamped on them as well.
          The hole for the key chain should be 9/64th's, not the smaller hole that seems to be so prevalent with current replacements.
          HaND
            • November 30, 1997
            Re: Knock Outs ?
            65's don't use gaskets between the lock cylinders and the door surface - only the stainless escutcheons.
            • Gary B.
              • January 31, 1997
              • 6994
              Key hole size
              Mike,
              In the survey I did with Pete Lindahl in 2005 on key ring, key holes size, we found that 7% (out of a sample size of more than 200 keys) of what we were told were original keys for 1953-1967 cars had the small key hole. Based on these data, I don't see how a judge could deduct for having a small hole on a key for a '65. Having said that, if I had a choice of a key with a small hole or one with a large hole for a '65 I would take the large hole key.
              Gary
                Director Region V
                • August 31, 1994
                • 1463
                Re: Knock Outs ?
                Hi Gary, nice article.
                I don't remember seeing a reference in your article, but, the large hole keys are also illustrated in the C-2 owners manuals.
                HaND
