Part # help -column bearing - NCRS Discussion Boards
  • Craig D.
    • March 1, 2001
    • 98
    I have a 1975 Non- tilt column that needs a new lower bearing.The bearing is at the lower end of the column and looks to be housed in a plastic sleeve, covered by a steel retainer and wire ring. Is there a GM part # still in service that will cover this application ? TIA, Craig
    • 43288
    Re: Part # help -column bearing
    Craig-----
    I THINK the part you need is GM #7805700. If so, it's still available from GM for about 35 bucks, GM list.
    • Jim S.
      • August 31, 2001
      • 730
      The bearing and hardware are all still available from GM and various Vette suppliers. The parts are the same for both standard (non-adjustable) and T&T columns.
      The bearing is the number that Joe indicated.
      Column Lower Bearing Adapter (plastic) GM 7805822
      Column Lower Bearing Shield Wire Clip GM 7804439
      Column Lower Bearing Shield GM 7804440
      The standard column has a spring between the adapter and the shift tube.
      Doc Rebuild lists it as 69-79 Thrust Spring 6521121.
      Jim
