1971 Horn Relay with Black Plastic Base_Wheer to Purchase - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    I have ordered two horn relays that were supposedly for a 1971 corvette--both have metal base not plastic like my original. Where can you purchase this relay. Metal cover with four letters on it. Thanks Paul
    • 3415
    Re: 1971 Horn Relay with Black Plastic Base_Wheer to Purchase
    Hi Paul,
    Have you tried Dr. Rebuild. The drawing (which he does) looks like it has a black plastic base. Page 183, Item M. I believe you can return his electrical parts if you don't open the plastic pouch.
      • 43220
      Paul-----
      You need to find an OLD NOS GM #1115889 relay (like I say, an OLD one because not all of these are configured exactly the same) or look to find a used example from some other 1971 GM car. These were used on other GM cars besides Corvette.
      • Paul C.
        • November 12, 2007
        • 511
        Any other suggestions--still no luck. I am still looking.
        Paul
          • 11643
          Type the part number in Google.
          I found many of them.
          Or, buy one from Standard Parts and install your original Delco cover (the top of the relay) onto it.
            • 43220
            Patrick-----
            Yes, one can transfer the cover. However, I believe that the current GM part, aftermarket equivalents, and even later examples of the original part number have a different configuration for the base section. So, if one is after 100% originality, I don't think one will "get there" this way.
            If one is just after a FUNCTIONAL replacement, no problem: GM #12339248. About 94 bucks, GM list.
              • 11643
              Patrick-----
              I paid far less for a Standard part last year.
              I'd go check the configuration, but the cars aren't at my house.
              Patrick
              • D S.
                • March 1, 2005
                • 1551
                Looks like this? It went for $99 on eBay last week. I see them quite a bit there because I'm looking for a '70 one.
                • Paul C.
                  • November 12, 2007
                  • 511
                  Scott: That is exactly the one I am looking for--I guess I will just keep looking. Thanks. Paul
                  • D S.
                    • March 1, 2005
                    • 1551
                    Paul, I have seen a lot of those pop up on eBay for '71s because I keep an eye out for the '70 889. I usually set up a Search and eBay emails me the item numbers as they pop up. I can alert you if you want me to. ss396t6@sbcglobal.net
                    • Jeff A.
                      • January 1, 2000
                      • 312
                      I sent you a PM.
                      I have a few of these.
                      have a bunch of the 890's too.
                      My Cars
