Clock and gauges handle color - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12867
    Was the orange of the '63 clock and gauges handles fluorescent or plain orange?
    thanks,
    Rob
    Rob.
    NCRS Software Developer
  • Andy F.
    • January 1, 2004
    • 93
    Re: Clock and gauges handle color
    Rob,
    I used a flourescent color to match my 64 guage needles and clock hands. I used a small hobby airbrush and paint. It turned out nice.
    • Jim L.
      • December 1, 1981
      • 50
      HI rob Be very carefull with the clock face and all other gauge faces when cleaning. The gauge faces on 63's and I believe maybe other mid years were applied with water based paints. Don't ask howI know this. Just do not clean with any liqiud and brisk rubbing. Regards JR
      • David D.
        • January 1, 2005
        • 416
        Rob, I have to agree with Jim...be very careful.
        If you want it done correctly OR you just want to discuss (send him an e-mail) I would like to highly recommend Harrison Speedometer, in Jupiter, FL.
        I spent several hours at his shop couple days ago and I can not say enough about Bill, his workmanship, quality and process. HANDS DOWN it is second to none....
        BTW-I have no absoluetly affiliation/connection with his shop or operation.
        Good Luck,
        David
        • Stuart F.
          • August 31, 1996
          • 4676
          David;
          Believe we are neighbors. Have seen your threads, recently one about gas and associated article in our Orlando Sentinel.
          I tried to put a quartz kit in my 63 clock years ago. Clock ran fine, but I could never get the second hand "pinched" onto the shaft correctly and it would drag on the face and slip going uphill. I want to change my oil pressure gauge too, but it will require I transfer the face and needle from my current gauge to the other borden tube mechanism. And I just don't feel competent enough to tackle it.
          Now, this shop in Jupiter, FL., is he the same fellow that had a booth at the winter meet? If you think he does good work, that's good enough for me.
          Stu Fox
          • David D.
            • January 1, 2005
            • 416
            Stu,
            Not sure we're close enough to be neighbors, and I've talked some about gas and prices, but nothing associated with an article in the Orlando Sentinel.
            Regarding Harrison's, I can't say enough about his work. The extra lengths he goes to doing the best on each and every piece was very impressive to me.
            I truly couldn't say.....we're only down in Jupiter for the month and then it's back home to NC, so not sure if he has been to meets or has a booth etc. But, In my opinion, if you have your gauges done by him, you won't be disappointed.
            Good Luck,
            David
