Sticker under hood 1970 LT-1 - NCRS Discussion Boards
  • Chris L.
    • November 1, 1998
    • 273
    Would the sticker found on the firewall above the master cylinder on a 70LT1 show 350/370 on the sticker or 350/350? Thanks
    • 43200
    Re: Sticker under hood 1970 LT-1
    Chris----
    The emissions label should be coded "CT", although it's possible other-coded labels were used, too. In the text of the label it says "350 cu. in V-8 360 & 370 hp." The same label was used for 1970 Z-28 Camaros and that's the reason for the reference to "360 hp".
    • Tom S.
      • March 1, 2004
      • 1087
      Joe you are the man !You never fail to amaze me! Tom
      • Chris L.
        • November 1, 1998
        • 273
        Thanks Joe....the car I have is a 350/350, however the console plate has 350/370. The motor has never been out of the car and it is an original 14k mile car. It was modified to look like a Motion Performance car back when it was new and I guess it's possible the original owner changed the console plate. It is a CTH stamped motor which is correct for the 350/350 with M/T. I took a photo of the sticker, but don't know how to include it with this response. Thanks
        Chris
          • 43200
          Chris
          Chris----
          If you wish, you can e-mail it to me and I'll post it for you. If it's an original 1970 L-46, I expect the emissions label code will be "AX", but other codes may also have been used through the model year.
          • Mark R.
            • September 30, 1990
            • 127
            Chris:
            When you figure out how to post a photo of the Emissions Label, it would be interesting to include a photo of the Baldwin Motion modified look car.
            Mark
            • Mark S.
              • April 1, 2002
              • 40
              Here's a picture of the emissions label from my 70 LT-1.
