C1 Turn Signal - NCRS Discussion Boards
C1 Turn Signal
  • Mark R.
    • October 22, 2006
    • 23
    C1 Turn Signal
    Does anyone have a picture of a working signal cancelling switch assembly mounted in the steering column housing? If so can they please send me a copy (markradin@live.com). Mine has never worked. Perhaps something is missing, broken or worn out. Should there be a roller over the studs that are above and below the actual electrical switch? Rollers that perhaps the sprung arms from the switch assembly rest/roll on? Any other comments would be appreciated. An archive search as not helped. Thanks
  • Gary C.
    Administrator
    • October 1, 1982
    • 17935
    Re: C1 Turn Signal
    Mark, here's a photo that Roy Braatz previously posted. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Mark R.
      • October 22, 2006
      • 23
      Re: C1 Turn Signal
      Thanks for the reply Gary -
      Seems the shafts that are above and below the actual electrical switch have brass(ish) rollers or bushes. They are both missing from mine. Any clue where I can buy them? CC and CA do not have them listed. When was Roys posting - perhaps he mentions a source in that. Thanks again.
      • Mike M.
        • May 31, 1974
        • 8408
        Re: C1 Turn Signal
        the parts you need are common to the 53 to 54 chevy pass cars. go junkyarding. mike
        • David K.
          • February 1, 1976
          • 592
          Re: C1 Turn Signal
          One roller missing on my '62 as well. So I found a used one to replace it. I did have the old mechanical switching mechanism, but bought new, to elliminate any problems. WRONG. The new mechanism DOES NOT work. I will not hold into right or left position. The geometry is apparently not correct. I rescued the old mechanism and now it works great. The trick though is getting the darn housing to get tight on the column and stay tight!
          • Dennis A.
            • April 30, 1999
            • 1010
            Re: C1 Turn Signal
            David...
            Great article in the spring 2007 restorer....Remove the lock wedge, and dip the contact surface partially in a rubberized coating solution. (Grip Dip or equal) dry for 24 hours and reinstall....
            • David K.
              • February 1, 1976
              • 592
              Re: C1 Turn Signal
              Thanks for reminding me. Now off to the store to get some.
