C2 67 A/C Freon question - NCRS Discussion Boards
+ More Options
Posts
  • Terry S.
    • January 1, 2006
    • 45
    Does anyone know how many lbs/oz of freon in a 67 A/C system?
    Thanks, Terry
  • Larry M.
    • January 1, 1992
    • 2701
    Re: C2 67 A/C Freon question
    Terry:
    The original label on the compressor of my 1967 327/350 HP factory air car indicates that the system capacity is 3 lbs of R-12 refrigerant. This should be the same for both small and big block cars.
    The 1967 GM Chassis Service Manual indicates Corvette system capacity is 3 lbs 4 oz of refrigerant.
    I would charge 3 lbs and use my high/low gage readings, drier sight glass, and inside duct air temperature to make final adjustments.
    Larry
    • Terry S.
      • January 1, 2006
      • 45
      Thank you for the info
