63 corvette hood latch - NCRS Discussion Boards
  • Robert P.
    • December 10, 2007
    • 1
    The passenger side hood latch on my 63 won"t release. Does anyone have any thoughts on how I can get the hood open?
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 63 corvette hood latch
    Bob;
    I don't know what to tell you. I sure hope someone gives you some advice on this as it has been a fear many of us have had over the years. I have not had any problem ever with not being able to open mine (since August 63), but I once had it popping open on that side every time I hit a bump. A little adjustment and lubrication cured that.
    Stu Fox
    • Tracy C.
      • July 31, 2003
      • 2739
      Can you reach up from under the car and touch the latch? If so, maybe you can trip the catch open with a slotted screwdriver.
      If you must raise the car, please use appropriate safety measures (jackstands) before getting under there...
      Good Luck,
      tc
      • Mike M.
        • May 31, 1974
        • 8400
        ya may have to remove the splash pans to access the hold latch. mike
        • Tracy C.
          • July 31, 2003
          • 2739
          Mike....what the heck is the story behind your Avatar pic.. Looks like yer all tied up with a rope and duct tape. Kinda kinky there ole buddy. anything you'd like to share with us?
          • Mike M.
            • May 31, 1974
            • 8400
            i was at a regional in canada years ago, and that despicable 63 team leader , peckerhead colclough, had me tied up and duct taped so i wouldn't interfer with the team judging my 63 ZO6. mikie
            • Tracy C.
              • July 31, 2003
              • 2739
              Sounds like a pretty dang smart peckerhead..
              Am I gonna see your sorry "A" in St Louis this year?
              • Bob B.
                Infrequent User
                • April 1, 1998
                • 9
                Hello Bob,
                Any fix yet? Seems things come in threes. I guess I'm #2! Same month, same year car, same right side. Jeeze... Who will be #3?
                I should have seen this coming. My hood latch release has malfunctioned. The passenger side has always been a little lazy. I mean for the last 35 years, not the last 35 days.
                I took a friend out for a spin. We get back; I back the car into its spot in the garage and pull the hood latch. I disconnect the battery each time I am done driving. The left side pops up released, and then the handle comes out just a little further that it ever has. But the right side stays latched.
                We tried all the same stuff anyone would. Pull again, and again. Close the left side and do it again. Bang on the right side while pulling. I was told somewhere that the definition of insanity is doing the same thing over and over again expecting a different result. So, I am now officially insane.
                Ideas? Advice? Solutions? Please?
                BobBower
                63 FI SWC
                NCRS 30287
                "Life Is A One Lap Race!"
                • Michael H.
                  • January 29, 2008
                  • 7477
                  This is a common problem. The right side latch isn't opening far enough to release, OR the hood has some tension on it trying to force it to the left which won't allow the latch to open far enough to release.
                  While a helper holds the release in the full release position, push on the center hump of the hood from the drivers side of the car, forcing the back of the hood slightly toward the passenger side.
                  This doesn't ALWAYS work but it works much of the time.
                  The right side latch needs to be adjusted toward the drivers side.
                  • John D.
                    • December 1, 1979
                    • 5507
                    Dr. Mike, I don't see your name on the registration sheets for the Seven Springs regional next week. What's the matter Doc. Hope you are coming. JD
                      If the above doesn't work (cable stop has come loose or cable has broken), remove the big triangular splash shield from the frame and underbody (3 screws) and go up from the bottom with a piece of broomstick or a long screwdriver or prybar and move the protruding latch lever forward. Helps to have someone push down on the hood while you do this to reduce the effort required to move the lever (against spring pressure).
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        You change the subject over here at this place too??
                        • Bob B.
                          Infrequent User
                          • April 1, 1998
                          • 9
                          Thanks Michael and John,
                          Looks like it's time for the floor jack and jack stands. Oh yeah, and working upside down in the dark. Yum.
                          Thanks for the help,
                          BobBower
                          63 FI SWC
                          NCRS 30287
                          • John D.
                            • December 1, 1979
                            • 5507
                            In life consistency is best policy.
                            • Bob B.
                              Infrequent User
                              • April 1, 1998
                              • 9
                              Fixed.
                              I was right about the brass release stop coming off the cable. As John suggested I was able to get up in there with a long rat tail file and pop the latch. What a sweet sound that was. I put the brass stop back on the rod, adjusted the position to actuate the latch sooner, and I'm back in business.
                              Now that it's up on jack stands I am seeing stuff I need to attend to in the hygiene department.
                              Thanks again for the help guys...
                              BobBower
                              63 FI SWC
                              NCRS 30287
