C1 carpet install - NCRS Discussion Boards
C1 carpet install
  • Michael L.
    • July 31, 2005
    • 562
    C1 carpet install
    When installing the gas pedal, do you slit the carpet to install the metal plate directly to the floorboard or bplt the pedal over the carpet?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 carpet install
    The pedal is bolted to the floor not into the carpet,the carpet has a so called slit made to clear the metal plate
    • John S.
      • February 1, 2003
      • 78
      listen to Roy....i have done 2 C1 carpets on my cars and the gas peddle is bolted first then carpet put on there def shud b a slit in carpet to fit around the gas peddle John...
