Who is correct, 65 Judging manual or L.I.C.S.? - NCRS Discussion Boards
  • Dwight P.
    • June 30, 1983
    • 176
    1965 Judging manual states that the bell housng inspection plate is secured with 4 recessed hex-head bolts. Typical head marks include "E" or "L" logo.
    Long Island Corvette Supply believes that slot-head screws are correct.
    Any guidance is appreciated.
    DP
  • William C.
    • May 31, 1975
    • 6037
    Re: Who is correct, 65 Judging manual or L.I.C.S.?
    Well, at least according to the '64 parts book, (to say nothing of maybe 10-15 engines I've personally disassembled) one clue is the clutch dust shield is held on by the same 1/4-20 bolt with lock washer as is the timing cover, GM part number 3817006, started use in the 1962 MY. The trusty OLD '65 JG seems to agree by the way with the NEW '63-64 manual on that, so that's what I'd be looking for. One clue might be that I have a LOT of spare Chevy engine bolts from the 62-up era in my junk box, but none are 14/20 slotted heads.
    Bill Clupper #618
    • Clem Z.
      • January 1, 2006
      • 9427
      the 14/20 are called "stove bolts" and they used a lot of them on the old 6 cylinder chevy engine and that is why they were nicked named "stove bolts"
      • Dick W.
        • 10483
        Personally, I believe that 1965 is way too late for the slotted screws. I do not ever remember seeing them in a '65
        Dick Whittington
        • Nick M.
          • September 30, 2005
          • 143
          I also have a 63 that according LIC, should have slotted screws but the JM says Hex Head. Anyone out there in NCRS land have the correct answer?
          • William C.
            • May 31, 1975
            • 6037
            According to the chevy parts book, '62 was the first year for hex heads. They have been used ever since. What LICS states is immaterial, and if you have done your own research prior to making a purchase of a part you will have to buy fewer parts a second time to get a correct one. Always remember, do your research first, then purchase. Do NOT assume a vendor has done your research for you.
            Bill Clupper #618
              • 15706
              My '63 inspection cover is still secured with the original 1/4-20 recessed 7/16" hex machine screws.
              oops
              • Clem Z.
                • January 1, 2006
                • 9427
                I my '63 inspection cover is still secured with the original 1/4-20 recessed 7/16" hex machine screws othewise known as "stove bolts".
                duke stove bolts are screw driver type bolts use on old wood and coal burning stoves and i am old enough to have seen and tighten them with a screw driver. plus they were all over the 6 cylinder chevy engines
                  • 43279
                  DP
                  Dwight-----
                  I absolutely agree with everyone else; I don't think that slotted head screws were ever used on the bellhousing lower cover for any 63+ Corvette.
                  • Eugene B.
                    • May 31, 1988
                    • 710
                    Dwight,
                    Just returned from garage to inspect the bolts in my very original '65.
                    The flywheel cover bolts are per the '65 TIM & JG. They are recessed head, star washer, bolts with a head stamp that has an L in the center that is surrounded with a large G. There are also three concentric rings around the G.
                    Hope this helps you.
                    Gene
                    • Ken A.
                      • July 31, 1986
                      • 929
                      Check the back of an original water pump.
                      • Dwight P.
                        • June 30, 1983
                        • 176
                        Gene:
                        Thanks....this is a big help. There is a lot of misinformation floating around that is frustrating.
                        DP
                          • 43279
                          Ken-----
                          Yes, waterpumps were an exception. For big blocks, the slotted screws were used until 1967. For small blocks they ended earlier but I don't recall just when. However, I am fairly sure the use of the slotted screws in the waterpump application had more to do with providing a little extra clearance between the rear of the pump and the timing cover. With short leg waterpumps, as used on ALL Corvettes, the clearance can be "touch-and-go".The thing that surprised me is that they EVER stopped using the slotted screws on waterpump backing plates; the clearance issues never "went away".
                          • Raymond D.
                            • January 10, 2007
                            • 22
                            My very original 2 owner small block 65 has the slotted screws.Since it was basically untouched when I got it( with the original radiator hoses) I have to doubt anyone would change over all the bolts to screws.
                              • 43279
                              Raymond----
                              For whatever reason, there seems to be exceptions to almost all "rules". I would say your car is the exception and not the rule.
