Who is correct, 65 Judging manual or L.I.C.S.? - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Who is correct, 65 Judging manual or L.I.C.S.?
    Originally posted by Raymond DiLena (46773)
    My very original 2 owner small block 65 has the slotted screws.Since it was basically untouched when I got it( with the original radiator hoses) I have to doubt anyone would change over all the bolts to screws.
    I dunno; the '65 TIM&JG calls for recessed hex for both lo and hi horse 327's.
    The 396 water pump is different; the originals with the flat back plate had panhead slotted screws with star washers. This pic is of a "284" with cast date E_5_5.
      • 43212
      Raymond-----
      Just so I'm clear on this, are you talking about the bellhousing lower cover screws or the water pump backing plate screws? For my previous response, I assumed you were talking about the bellhousing lower cover screws.
      • Raymond D.
        • January 10, 2007
        • 22
        #18
        Joe, I was talking about the clutch cover inspection plate.Ray
          • 43212
          #19
          Ray----
          OK, thanks, I interpreted you correctly and my response remains as stated.
          • Wayne M.
            • March 1, 1980
            • 6414
            #20
            Raymond -- Mea Culpa; you initial thread sort of bifurcated, by others, into whether slotted (panhead) fasteners were used on motors in 1965; someone mentioned waterpump backing plates and I jumped in (where maybe I shouldn't have).
            That's one of the drawbacks of this current discussion board format (versus old faithful ) where you could see the change in flavor from the original post, as subsequent posters modified the title to emphasize an additional aspect of the original subject.
