Folks,
Just recently had my starter rebuilt and after attaching to engine with the two hex bolts the support brace bracket won't align. Car is '66 327-cid. I thought I had an incorrect starter brace already on the car (as I'd discovered in years past some parts installed by previous restorer, etc., came from non-1966 model year) and went to mid-year corvette supply catalogue and discovered that there is only one starter brace for my engine, year 64-67, so buying a new, replacement brace doesn't look like it would solve the problem. Several years back when I removed the starter (for other undercarriage work) and replaced I remembered having a difficult time with the alignment of the brace bolts, but not as bad as this time. The 'boomerrang' sparkplug wire shielding appears correctly installed and the indentation in the shielding appears made for the starter's brace, however, the hold-down bolt on the end of the starter's motor which attaches to the brace is ~10-20 degrees off rotation. Could it be possible that the starter rebuild shop inadvertently rotated something so that now the brace's bolt at the motor is now off alignment? I did have the shop dissassemble the motor, refurbish the guts, and install new solenoid. Is it possible to have this corrected? The part number of the starter is 'correct' for my car's year and application. Anyone else have this issue?
