63 water pump bolts - NCRS Discussion Boards
63 water pump bolts
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 990
    63 water pump bolts
    I'm helping a friend restore his '63 coupe. Can someone tell me if all of the water pump bolts are painted engine color?
    Thanks.
    Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • 43258
    Re: 63 water pump bolts
    Thanks.
    Tony
    Tony-----
    Yes, they were painted with the engine. However, I don't think that the upper, right side bolt (the one that also retains the alternator brace) was painted. I believe it was installed at St. Louis.
    • Tony S.
      • April 30, 1981
      • 990
      Thank you Joe.
      • Art A.
        • June 30, 1984
        • 834
        Actually Joe, the alternator bracket bolt was painted as it was part of the engine assembly as shipped and removed at St. Louis and reinstalled for the bracket retention. See AIM, UPC 6 sheet A2, which is for 1965, but I'm sure it applies to most years where this applies.
        • Michael H.
          • January 29, 2008
          • 7477
          Art,
          The 63 MY was slightly different than 65. At the St Louis plant, the existing water pump bolt was pitched and a new bolt and washer were used when the alternator brace was installed so there should be no orange paint on it.
          I don't remember when this process changed and the original orange painted bolt was reused. Does the 65 AIM show that a lock washer was added? If so, that would be unpainted.
          • Art A.
            • June 30, 1984
            • 834
            Michale, Since I don't have a 63 AIM to verify,I assume that I stand corrected on the 63s. The 65 AIM does show the bolt and washer as part of the engine assembly as shipped so they would have been painted.
